a/c stop working
I not found new valve without evaporator and just remove internal parts from expansion valve (nut, spring, needle) put all back together and its works, when outside temp about 90 F I have 35-40 F inside, low pressure little higher then normal (about 55 psi), but its ok.
The following 2 users liked this post by Guillaume:
al_roethlisberger (07-25-2015),
overtheatlantic (07-25-2015)
I just posted in an adjacent thread the problem of installing the dryer canister in backwards as mine was originally. There is definitely a right way and a wrong way to install it. The right way the screen holding the pellets can still clog up but will not get pushed out of the way and let the pellets escape into the system. The three inch segment in the tube holding the pellets must be at the exit end of the dryer tube.
al_roethlisberger (07-27-2015)
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
