cam cover corrosion
Yes, they will eventually corrode through. I reckon your coil/s will be arcing a spark to the cam cover which accelerates corrosion. Look for cracks in the coils. Have your cam cover painted. I've heard varoius suggestions over the years about how to insulate coils or prolong their life. Some suggest using the more modern spark plugs and fitting a rubber sleeve over the coil.
In the first instance, check the coils for cracks.
Dickie_L_J_O
09-13-2015 07:44 AM
jagent
09-12-2015 09:10 AM
