Need information on how to replace DBC 10603 code po340 hard start but run great but hard to start. I replace the lower sensor at the crank
shaft but still hard to start . I like to replace the DBC sensor, I have check wire plugs for breaks oil . it has to be that DBC sensor 1995 xj6 X300
1995 xj6 just need to know how to set the DBC in correctly how to set TDC correctly
