Camshaft position sensor leak
Received 13,255 Likes
You can easily look up exploded parts diagrams at jaguarclassicparts.com
Assuming your Jaguar is an X300, the O-ring you're interested in is part 8 in the diagram below:
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/400x492/sp5785b_9499088ce1ab929a0dee3ce47f04f65bfae39a0f.png)
You can see the part names and numbers at this link:
https://www.jaguarclassicparts.com/i...es/sp5785b.png
By the way, while the engine management and workshop manuals call it the Camshaft Position Sensor (CMP), the parts catalog for some inexplicable reason calls it the "Ignition Position Sensor" and the "Engine Position Sensor." Go figure!
Also, it helps others give you the most accurate replies if you will add the year, model and engine details of your Jag to your signature. Just use your User Control Panel to edit your signature and add these details and they'll show up in all of your posts.
Cheers,
Don
The following 2 users liked this post by Don B:
motorcarman (04-29-2019),
MountainMan (05-03-2019)
Don B (04-29-2019),
Grant Francis (04-30-2019),
Hello Don and Grant,
Thank you for your input. I have my signature set up, not sure why it didn't show. I'll have to review my settings once again and see if anything changed. But this is on my 1997 Jaguar XJ6 4.0L with 175k. I replaced the valve cover gasket and plug well orings but they ended up leaking, so I decided if I am removing the valve cover once again I should take a look at the other leak. I will end up purchasing the O ring and gasket for the timing chain tensioner and the gasket for the Ignition Position Sensor / Engine Position Sensor / Camshaft Position Sensor LOL
If anything once I take care of this I will let you all know what ended up being the culprit.
Thank you
Thank you
The following 2 users liked this post by jacklynthejag:
Don B (04-30-2019),
https://www.jaguarforums.com/forum/x...emoval-195908/
I may still have a few of those o-rings. They're viton, if you're interested.
Don B (04-30-2019)
bigalan
07-29-2012 10:45 AM
bforsik
07-26-2012 05:59 PM
