Can anyone help me identify this?
I replaced the reservoir sensor in my XJ today and everything is working fine. Before I button it up again, this plug is hanging loose and I can't identify it from the wiring diagrams. Anyone know if this is for the headlight washers I don't have? Something else I do have?
Thanks in advance.
Thanks in advance.
someguywithajag (01-29-2017)
The following 3 users liked this post by al_roethlisberger:
Al is spot on, it is indeed the connector for the power wash pump for the headlights.
There should be a dummy relay (identified by white stripe) located in front of the relay box on the right hand side. Connections are easily identified by the thick yellow/red wire.
I have attached relevant page from wiring diagrams.
John Herbert
John Herbert
The following 3 users liked this post by John Herbert:
