Can I put BMW wheels on 1996 Jaguar XJR ?
Hi All,
I am looking for 16" rims for my Jaguar XJR because roads here in Tbilisi, Georgia are not the best, I mean it's way better then i remember 10 years ago, but still - driving with my 18" is killing suspension (which I already need to fix all the bearings and ETC ... )
So, long story short - there's no rims i can find 16" in here. My question is :
Can i put 16" on the XJR at all ? and if i can - can i use BMW rims ? As you can find them cheap - 200 - 300 USD for a set with rubber on it.
I know the bolt pattern on XJR is 5 X 120.6 and the BMW is 5 X 120
Alex
Alex
Received 10,880 Likes
I'd bet on it being fine as long as you get the centre bore right (which will require work), use the correct bolts for the wheels, & make sure you pick some with the correct offset. IIRC E34s are in the right ballpark offset wise, but something like an E36 isn't. Not sure on more modern 5ers, but I'd expect them to be more likely than 3ers. Oh, and they don't all use the same CB either.
In conclusion, I reckon it's doable, but there's plenty of ways you could get it wrong!
Hmmm. Not sure with the 205s on, but I think they're more likely to be 7J from an E39 than 7.5J (E28 M5 / E30 M3) or 8J (E38)? If so, they're ET20, which should go under the arch ok on a 7J rim, although not strictly correct. IIRC E39 rims are a bigger CB than most BMWs, so you may need spigot rings rather than machining on the wheels.
![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
The biggest risk is likely to be the wrath of fellow members.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
On a more serious note - good luck. I hope you can get a fit.
225/60 or 55 is the standard 16" tire size for x300 Jags. Those tires in the pic might be too short (low profile). With the other unknowns, it would be wise to try them on before buying, if you can!
If the wheel center bore is correct then each lug will be a tiny amount off center. It can be done, but you would want to tighten down the lugs very evenly to reduce the chance of unequal stress, and hopefully avoid vibration.
I dont much like the idea myself, and a tire shop might refuse to do this altogether.
Regardless, please let us know what you find out!
I have aftermarket BMW mesh wheels on my x300 and the only thing I had to do as other members have said is get the center bored out to 73 or 74mm, I can't remember exactly but BMW hub is 72.1/73.1 so it's just a bit smaller and I also had to take the dust cap off of my hub.
Here is a picture of my wheels.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/60656-can-i-put-bmw-wheels-1996-jaguar-xjr-1010602_4827279210009_1072287905_n.jpg?dateline=1383199811)
Most 5 stud BMW wheels are 72.5mm CB, but E39 wheels are 74.1mm. So E39 wheels will go straight on, but you may find the slightly-too-big (by 0.4mm IIRC?) CB gives you issues. Do you know what BMW the wheels you've found are from?
E39 wheels on an X300: https://www.jaguarforums.com/forum/x...e-73191/page2/
WTB[NorthEast]: 17, 18 wheels from xjr, xkr etc
88xjs_Tony
08-28-2015 11:17 AM
