Can overfilling of oil cause problems?
Received 3,901 Likes
AJ16er, if it is only 1/2 a quart past the full mark, I would not worry about it. Worst case, you may see a slight drop in mileage due to the crank having to slosh through the oil as it is spinning. As long as you are not hearing any noises, I would call it good.a little extra doesn't really hurt anything.
