Car overheating after HVAC hose busted!
When Jaguar changed the wiring so the fans came on when the ignition comes on they did it by installing a jumper in the system. You can see the jumper easily if it is there. Look on the right rear of the engine compartment very close to the firewall close to the cam cover. It stands out since it doesn't look like the normal wiring. There is a wiring connector that has been disconnected and a jumper plugged into one side of the connector. If you remove the jumper and put the connector back togrther the fans only run when the tempt switch tells them to. But, you want the jumper there.
etaent (10-17-2013)
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
