Car overheating after HVAC hose busted!
Old 10-15-2013, 11:50 AM
etaent's Avatar
Ok did what you guys said and the fluid began bubbling out of the tank like crazy! I shut the car off after that but the problem continues. Car still over heats and fans don't turn on automatically like they used to. They don't even turn on when I put th a/c on. Any ideas?
Old 10-15-2013, 01:01 PM
mikesmith2's Avatar
The bubbling is the air coming out of the system.
You need to do that until no more bubbling, then the air will be expelled.
You need to check the relay, is power going in and coming out?
Old 10-15-2013, 02:05 PM
etaent's Avatar
There's definitely power going to the relay. I'm going to try what you said about the bubbling.
Old 10-15-2013, 03:57 PM
etaent's Avatar
Thanks to everyone for your help! I decided to try the thermostat and boom! The car no longer over heats and the fans are working as they should! Turns out the thermostat burned when the car overheated! RESOLVED!
Old 10-15-2013, 04:17 PM
mikesmith2's Avatar
Excellent news. Glad you got it sorted.
Thanks for updating us with the result, not many do.
etaent (10-17-2013)
Old 10-15-2013, 04:27 PM
EZDriver's Avatar
When Jaguar changed the wiring so the fans came on when the ignition comes on they did it by installing a jumper in the system. You can see the jumper easily if it is there. Look on the right rear of the engine compartment very close to the firewall close to the cam cover. It stands out since it doesn't look like the normal wiring. There is a wiring connector that has been disconnected and a jumper plugged into one side of the connector. If you remove the jumper and put the connector back togrther the fans only run when the tempt switch tells them to. But, you want the jumper there.
etaent (10-17-2013)
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
Jaguila
09-05-2015 06:16 PM
daro31
08-27-2015 09:26 AM
dpappyp
08-27-2015 06:31 AM
Quick Reply: Car overheating after HVAC hose busted!
