Car starts and dies after modest acceleration
Car had been parked outside for a few weeks. It had been running fine previously. A Large rat built a nest in the rear right side section of my engine compartment using Hood Insulation material. I drove the car to a local wash station (ran fine) and vacuumed and used high pressure water to clean out the mess including feces at a local car wash. Car ran ok in the parking lot and then stalled after 1500+ RPM. Some guys helped me push the car to a safe spot. An hour later the car starts but dies as soon as I hit the accelerator past 1500 to 2000 RPM. Next day after a few tries I was able to drive the car home at very low RPM speed. Since then the car won’t even start. I’m guessing I damaged something when I cleaned the engine compartment (right side only) or I got water into something I should not have? Any suggestions on how to proceed would be greatly appreciated.
If it is a X300 probably the CKPS sensor connector on the very front crankshaft pully
The CKPS does not have a splice in the wiring to the ECU that water can short out
There are 2 / 13 pin square connectors together on the right side on the rail / chassis coming back from the right headlights , water can get in both as the connectors halves mate together and in the wires going into the connector halves ( there are water seals on the wires but........ )
There are some engine regulation wires in these connectors
The O2 sensor connectors can get swapped by mistake if you remove them so do 1 at a time
These are the 2 / 4 wire black connectors on the right side
As you have probably now realised, a pressure washer was likely a bit extreme for washing the engine compartment, although I can well appreciate your desire to remove any trace of rats. Could you have blown off any wires on the inlet manifold? I am thinking about the throttle position sensor in particular. You may have forced water into it, which is not good, but it might respond to some attention from a hair dryer or the like? If the engine is running on all cylinders, I would be tempted to focus on the inlet manifold, including the mass airflow sensor, which is also unlikely to have enjoyed being blasted, and might also respond to a hair dryer.
The CKPS as a fixed nonadjustable bracket that can be removed from the front
10mm socket
You can then pull it up and out to replace the sensor on the bracket
If you remove the hockey puck camshaft position sensor ( with the adjustment window on it ) you will lose the adjustment on that
The camshaft position sensor is only used in the very beginning of the start sequence
The crankshaft position sensor is generic and not specific to jaguar so a local auto parts store will have them
10mm socket
It’s been raining for a few days so I wasn’t able to work on it, but to my amazement the car started right up and I was able to rev it past 3000 RPM without it dying. Today I tried again and it started right up and I drove it around my neighborhood and it ran fine. So perhaps when I washed the engine the water got somewhere it wasn’t supposed to and letting the car sit for a few days it dried out? Kind of strange.
