Car won’t start in Park
Having an issue with getting the car started in park. It will start when I shift into neutral. All the indicator lights on the shifter are reading correctly. However I’ve noticed recently it takes an extra wiggle to make sure it’s in park. It rolled back on me a couple times. Is this a neutral safety switch issue? Can that cable be adjusted?
Does the starter solenoid relay click by feeling it as another relay close by will also click and you will hear both
The starter solenoid relay gets a command ground provided by the BPM
For the BPM to provide this command ground it has to have agreements / . enables like a ground path through the ignition switch and other things
Pic coming
Pic coming
adjusting the selector cable is also something on my list to do.
as occasionally when i put it in park it is not quite in park, and i need to take it out and put it back in to get it to start.
very occasionally.
and going from D into R i need to move the lever just up past R before locking it into R as to engage the reverse lights and my newly added reverse camera\
very occasionally.
Parker 7 (12-06-2022)
vdpnyc
08-26-2016 12:30 AM
