Car wouldnt start, then all of a sudden started, please help...
hi everyone, today I was on my way to the gym, got into my car, turned the key, and it wouldnt turn over. There was no crank at all, just dead, all the power was working as I had my ac on and the radio and it was all working, all the lights were on the dash so I know it couldnt have been the battery. So I tried about 2 or 3 times and it wouldnt start. So I got out, locked the door with the alarm and waited a min, hopped bakc into the car and it started fine..... Really weird.... does anyone know what may have caused this? I had a new starter put in about 2 years ago, also a brand new fuel pump relay as well. Could it maybe have something to do wiht the alarm system? I do have a auto start remote alarm system that I had installed about 2 years ago, but its the first time this has happened to me... any ideas would be appricated. Just dont wanna get stuck in the middle of somewhere with the problem, thanks!!
Received 2,190 Likes
there are several things I would check. Start with ALL connections from the battery to the starter. I would loosen, wiggle back and forth to clean and retighten. Do this to all power and grounds. The other issue is the exciter ring that reads the key around the ignition barrel in the column. If memory serves it sshould ohm out at 33.4ohms pretty much exactly. If not replace it. Dont discount the battery, do a load test. I just had one today that I think had a loose plate connection. It had 12volts till you hit the starter then it just clicked. I had no amperage and when hooked up a booster pack drew it down too. replaced the battery and all was well. I dont think this is your issue, but just dont forget the obvious. There is a wire that kicks the starter when you turn the key and you may want to make a jumper to activate the starter independant of the key if it does it again. You just turn on the ignition and then jump the starter wire(its small about 12 gauge wire coming up from the starter by the firewall.)
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
