Carrier bearing removal
Assuming you have worked on cars previously, it will be obvious once you get under the car. Bur why are you doing this? Did a mechanic tell you they were bad, or are you just guessing? What about the rubber donut (guido)?
In the sticky "How To" you can download the parts and repair manuals.
I would like assistance with this as well. I just replaced the flex joint on my 95. When doing so the rubber bit inside the center u-joint just ripped off from being so dry-rotted. Someone said I have to buy that section of the drive shaft now..
The center support bearing is available separately.
Make *very sure* that you carefully mark the existing location of the bearing on the driveshaft and the location of the center bearing bracket on the underbody of the car. You don't wanna lose the original mounting positions. If you do you'll likely end up with a vibration and will have to (seemingly endlessly) experiment with the sliding adjustment to eliminate it.
piper 888 (05-04-2023)
aholbro1
08-05-2021 06:02 AM
