Center console and door lighting going out over bumps.
My door switch lighting on both front doors and my center console lighting go out and come back on simultaneously when I hit a bump. Any advice on where to start or a wiring diagram that I can locate a likely plug or ground that is going bad?
Before I forget a X300 came into a salvage yard Thursday that may have a original alternator for the taking , I didn't look at it as was looking at other things .
Now back to your lights
See page 92 or abouts
Is there a group of lighting in the print that matches your issue ?
I see a single bulb center consol switch pack and a driver and pass door switch pack , is that the area of interest ?
They have different grounds so that rules that path out
By putting the small dimmer knob on the steering column to override does that make a difference as you test drive it ?
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Bed time now
Bed time now
Ric in RVA (01-19-2019)
You need to clean and tighten the grounding stud on the back of your head unit.
https://www.jaguarforums.com/forum/x...09/#post338514
Thanks for the help and ideas!!!
Lady Penelope (01-21-2019)
AlexPeel
02-21-2017 06:03 PM
BillDJohnson
06-19-2013 09:04 PM
JaguarXKR
05-04-2011 10:39 PM
