Charred Spark Plug - Normal?
I just replaced the spark plugs on the AJ16 and I have posted a picture of what it looked like...
The car has 60,000 miles and I'm not sure if the plugs are original or not.
No dielectric grease was used on any of the boots.
Is this normal? I've never seen the ceramic cylinders get charred like this.
If it's any help, I had the same thing on a few of the plugs that came out of an XJR. I figured it was due to slight pressure leakage around the valve cover combined with high heat. The "hemi" style plug location seems to cause darkening around the plug when they are run for extended periods before changing? I have noticed this darkening on Toyota engines as well that have recessed plugs, so I tend to think it is more or less common. I'm thinking it doesn't take much oil vapour to cause this sort of thing. Since replacing the cover gasket, I have not noticed any further darkening, but it's early days yet.
Just a thought.
Just a thought.
Received 2,263 Likes
