Clunk clunk clunk
Hi Guys, I have a 94 XJ40 with the X300 rear suspension arrangement.
I've got a persistent clunk over ruts and potholes but car is nice and smooth on the highway. In the front, I've replaced the shocks and both upper cushions and and lower shock bushes, all OEM.
In the rear, I've replaced the shocks (Bilstein), so lower bushes and upper isolators got done too.
After replacing all this stuff, the clunk still was still there, maybe not as severe for sure, but she still isn't riding like I imagine it should.
Chasing down this clunk and not getting anywhere, I replaced the rear springs and the large sub-frame mounts, again all OEM.
Still clunky - bummer!
Any ideas?
Larry
Any ideas?
Larry
Received 12,932 Likes
Cheers Don
Larry
Here are photos showing the driveshaft center bearing replacement:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
The following 3 users liked this post by Don B:
Hey Larry,set the stands under each side of the rear suspension,so it is loaded with the weight of the car,good lighting,and a long heel bar.
With a little careful prying,you will spot the metal to metal contact point.
Good idea to check exhaust hangers too.
After I replaced the rears in Cin's car,there was a noticeable 'thup thup' going over speed bumps etc.,but after some miles on the new goodies,things have settled down
Hang in there!
Jim an Cindy
Hang in there!
Jim an Cindy
Lawrence (10-04-2014)
I don't know if there's a spec for movement, but if you've never rebuilt the transmission mount, it's time... It's not hard, just look up the info in the Jag-Lovers archive about the mistake in Haynes about the order in which to reassemble the parts. I think Groove was one guy who made note of it.
Cheers,
Don
Cheers,
Don
cheers
Larry
Hang in there!
Jim an Cindy
Hang in there!
Jim an Cindy
![Icon Nut](https://www.jaguarforums.com/forum/images/smilies/icon_nut.gif)
This undercarriage stuff is never ending, ain't it - I can see why Don replaced everything on his car now!!!
all the best
Larry
Chuck Schexnayder
33
10-24-2015 10:20 PM
philwarner
09-16-2015 10:40 PM
