Clunking sound on bumps
Old 12-17-2022 | 05:09 PM
Parker 7's Avatar
Old 12-17-2022 | 07:10 PM
Gatucho's Avatar
Updated: I had to use the factory method of pulling the fulcrum bolt to get the shock assembly back in. I used zip ties where you would have the chain and cut them off after the assembly was in place. All done.
I used a thinner bolt to hold the shock in place as it was easier to remove once in place
Parker 7 (12-17-2022)
Old 12-17-2022 | 08:28 PM
motorcarman's Avatar
A small 'scissor-jack' between the hub and 'bump-stop' will lever-down the hub enough to get the spring/damper OUT.
I remove the caliper and hang it out of the way.
Twirl the damper top mount and remove from the car.
The following 3 users liked this post by motorcarman:
944play (12-17-2022), aholbro1 (12-17-2022), Parker 7 (12-17-2022)
Old 12-18-2022 | 04:47 AM
countyjag's Avatar
As has been said already, each to their own...
The A frame removal method enables both shocks to be tackled at the same time, does not disturb brakes , suspension arms or sensors, and avoids the use of spring compressors. Just sayin' ...!
Old 12-18-2022 | 04:51 AM
countyjag's Avatar
In reply to the earlier question, the A frame removal method simply entails unbolting the A frame plate and removing it. Using a jack under the suspension arm, release the lower shock mounting bolt, and unwind the jack to decompress the spring. Undo the 4 nuts holding the upper spring mount to the car, and the entire shock spring "unit" can be removed from the car.
The following 2 users liked this post by countyjag:
944play (12-18-2022), motorcarman (12-18-2022)
riazp203
06-14-2022 01:14 PM
tjb909
03-11-2022 02:26 PM
Giojim98
02-15-2022 09:03 PM
Povilas Ghah
10-06-2017 10:41 AM
jvegas
04-03-2015 09:03 AM
