codes
so these are oxygen sensors and catalitic converter codes except for hydralic pump issue ? where is the pump i dont believe my car has one it has powersteering pump any further assistance on repairs if needed would be helpful thank im new to jaguar ownership and would like to he 95 i own all the love it deserves...
thanks for the input i used a innova code scanner to retrieve the codes my car is a 1995 so the codes dont matter for inspection purposes i just wanted to see what codes it would spit out and how to repair them if any were needing repair theres no check engine lights on or anything or abs lights so i will use all input and determine repair methods appreciate all input
have not gone any further no lights on dash and recently did rear wheelbearing so maybe the sensor was giving code after having all apart reset codes and have not re-scanned probably gonna do front brake pads soon and will go from there couple other things i would like to do as well nothing really affecting operation runs, stops, goes, so alls well at the moment thanks
philwarner
25
06-26-2021 05:43 AM
