Cold air exiting under steering column when heat is on, why
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I'm curious if the following is normal, although I can't imagine that it is...
When I have the climate control fully automatic, and the heat set high enough to deliver hot air, I will have cold air lightly blowing from the gap under the steering column between it and the knee bolster. So even though the system is delivering hot air at the floor or out the panel vents, cool air lightly blows on my knees and is quite cold.
This cold air only blows out of this gap at highway speed, and if I set the heat to near maximum (80+ F) then the cold air is stopped. If I am just driving around in town the cold air doesn't seep in. So it seems tied to speed, and perhaps some damper/flap setting.
So unless is normal for the system to mix cold air and blow it out under the steering column, this seems abnormal. It is?
If abnormal, any idea what damper/flap may be malfunctioning or other ideas how the cold air is being pushed in?
And just to re-confirm, I am getting full heat from the system so the circulation pump is fine.
Mine performs the exact same way, Al.....with the exception that I get it at slow-speed/idle as well, but at reduced flow-rate. As best I recall, manually setting the mode doesn't defeat it, either. In the summer, I don't notice a flow path there, either hot nor cold.
It sure seems a big mistake in climate-control design, which DOES happen from time-to-time. If a flap actuator is failing, it should flag a code on the self-test, I should think.
al_roethlisberger (12-21-2016)
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Ah, well good to know I don't have something else to add to my fix-it list
Kevin,
It has to do with heating....believe me, if it did this in DFW in August, I'd surely notice!
My first thought was that a firewall grommet had rotted or fallen out. Inspection revealed no such problem.
Now, I am convinced it is air from the HVAC that has somehow bypassed the heater core. My hunch is that it is post-evap core air, as it would be very prominent in summer if it were ambient. Could well be a foam flap-seal or some such thing has given up. Set-point significantly above cabin-temp makes it stop, but no amount of fettling with the manual distribution modes does, so I have to conclude it is a designed-in bleed, though for the life of me, I can't IMAGINE what they were thinking.
