cooler fans
The cooler fans have 2 fuses located in the engine compartment LHS front fuse box. Fuse #11 and Fuse #17.
I had a similar problem in the past where the cooler fans continued to run long after turning off the ignition. I removed the fuses and replaced and it fixed the problem.
Please note the the fans are designed to continue running for a period of time after turning off the ignition, this is normal
I hope this helps.
I hope this helps.
19jag95 (09-25-2015)
You should also read this thread for more info too
https://www.jaguarforums.com/forum/x...uously-149791/
