Cooling fans overworking
Hello folks, I have noticed that my cooling fans are working at an extreamly high rate after driving. My temp gauge is fine at mid section always. However after pulling in at home after work on or a red light the fans are blowing like mad. Cooling water level is fine and engine runs perfectly. Any ideas what I should check for... Thanks much,
Rique
1998 XJ8.
Rique
1998 XJ8.
Another thing to check is the water pump. If the XJ8's use the same OEM plastic impeller water pumps as the XK8's, the vanes will disintegrate over time, and especially if the engine overheated, and will run loud and long trying to circulate the water and bring down the temperature. These higher than normal temps are also very destructive to the plastic bodied secondary tensioners.
mikiep
12-20-2019 07:37 PM
