Cooling fans running at shut down - 1995 XJR
Old 03-12-2020, 06:38 PM
Cafcpete's Avatar
It can be normal!
There is a TSB to modify the fan control to this spec.
http://www.jagrepair.com/images/TSB/...%20Failure.pdf
See if you have the shorting link as stated in the above.
Old 03-13-2020, 06:39 AM
piper 888's Avatar
Thanks Pete, I will check this out on Sunday! Never knew what these plugs were servicing, this forum is invaluable!
Cafcpete (03-13-2020)
Forcedair1
05-14-2023 03:28 PM
toronadomike
08-07-2022 03:41 PM
Jjscruggs1
08-02-2017 04:40 PM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
Quick Reply: Cooling fans running at shut down - 1995 XJR
