Costly error of omission?
I'm storing my '96 XJ6/X300 for the winter. The battery went down and I bought a trickle charger for it. The first time I charged it, I disconnected the battery and ran the charge. It was fine.
This time I forgot about introducing electrical impulses into the system. I charged it for 24 hours. When I disconnected the charger and tried to start it, it was lifeless. No response from the starter, I think I heard the fuel pump run, the initial instrument panel lights all came on, but that was it. I just sat there in disbelief. Slowly I remembered the caveats about jump statrting and remembered disconnecting the battery last time. Also the shifter will not move from park.
I fear I have compromised the entire electrical system. I did just read some info from the forum suggesting the alternator diodes burning out, but I can't explore the forum fast enough to allay the creeping feeling of dom for my newly purchased (last summer) cat.
Will the funeral director please come forward?
sjagerson
sjagerson
Attachment 36316
sjagerson
Attachment 36316
sjagerson
I used to keep charging my batteries in order to get my monies worth out of them but its really false economy when you have an expensive car, as the last thing you want is break down at the side of the road.
Where bad things can happen if you have to leave it to go and get help.
Buy yourself a New One if its past its best and as for myself I use the old ones on my diesel compressor where its not a problem if the battery fails and then weigh it in at the scrap yard when it does.
During Winter Storage, I always/always/always, take the battery off.
What type of trickle charger did you use? Manual, or automatic with float mode charging? If manual you probably fried a weak battery.
I have several vehicles/tractors/snowmobile, so I'm always dealing with batteries. I finally bit the bullet and bought a conductance type electronic battery tester:
YA2612B, Tester, Battery, Electronic, 12 volt
I bought it used from another forum. It's saved me several times when I didn't believe the problem was a dying or dead battery but this tester showed the truth. I also have several battery chargers, and use two of these the most:
Home page - Batterytender.com
It might be worth your while to invest in an excellent tester and automatic charger if you will store any vehicle for a length of time. If you don't have a good tester, can you take the cap off and use a hygrometer? If not, remove the battery and have it tested at a garage. I bet that's the problem.
Costly Error of Omission
Wow! Thanks for all of the posted responses. After reading the info found on the forum (after 28 days of not being started it goes into "sleep" mode) I used the original key to unlock the cat and it started right up! It still had some problem locking from the remote on the first try.
My anxiety has abated, somewhat.
I will purchase another battery. I already had a battery tender, but was reluctant to use it full time as it is stored in another person's garage.
Thanks again. I'm sure to be asking more questions as I get back on the road this spring!
Scott
Scott
You won't fry an ECM with a modern low current trickle charger.
You certainly can fry it with a big beefy charger. I speak from experience.
It is important to make a 'clean' reconnection when replacing the battery terminal (-ve last always). Don't dither, that can cause spikes and problems.
To jvitez,
Thank you for your help. I was using a battery tender trickle charger which automatically shuts down after reaching the desired charge. It seems like the perfect tool. I'll get a new battery to start spring off correctly. Again Thank you all for your advice and support.
Scott
Scott
What do you consider "beefy"? I used a common 2 or 10 amp selected charger from Sears, probably puts out more of a square wave than real DC. Is that a bad idea?
First ... gorgeous colour.
The one thing to watch out for when disconnecting/connecting battery cables is to be swift and firm to minimise sparking. Once that cable is on the terminal, hold it firmly against the terminal while tightening so that contact is maintained. Again to prevent sparking.
If the battery is connected, it acts as a damper and the sparking of the battery charger cables is not really a big concern.
If you are concerned about imposing on your host you might consider using a simple household timer to turn on the battery charger for an hour every couple of days or once a week.
Your other alternative is to take the battery out and bring it home. Once there, ensure that the charge is maintained.
A brand new battery will only be partially charged. They benefit from a full 24 hour trickle charge before being put into service.
jimforrest (uk)
02-28-2019 06:42 PM
LilaJagHubby
10-06-2015 02:56 AM
