couple questions on oil change procedure
Received 10,871 Likes
Nah...just replace it......it's already like "pulling teeth" to get the wife to wash dishes.....
Seriously, though....I've not yet found a screw-on, cartridge type oil filter that doesn't come with the rubber gasket, though I suppose they exist. Everything I've seen lately, it is integrated and permanently affixed though I seem to recall some waaay back in the day that were just loose in the box.
I am able to unscrew the oil filter, turn it so the filter's mating end is up, and snake it up and out (versus lowering towards the ground). That way I am able to remove the filter without any oil dripping down.
Installation of the new filter is reverse of removal - guide filter (mating end up) down through hoses (left side of intake runners) ... I grab the filter with my right hand (routed on right side of intake runners) to screw it on.
On the XJR6 with the supercharged AJ16S engine:
It helps to TEMPORARILY remove the support brace between the engine block and the supercharger/intercooler assembly. Otherwise it is very difficult/impossible to remove the oil filter (at least on mine, which is a California emissions XJR6). I always reinstall the support brace after I replaced the oil filter.
Christian
Christian
MC36
US Lower Atlantic
09-01-2015 07:34 PM
