Crank No Start 1996 X300 - no fuel delivery
BOOM Spark!! It was that #5 Relay. I actually ignored previous advice about it because I thought the fact that it said "(AJ16)" next to it in the manual that it meant it was the v8 or supercharged engine and wouldn't relate to my inline 6, especially when I found no relay in there, and switched it for one that I guess was actually bad. Then I looked into what (AJ16 meant...). I went and bought a new 5 pin relay at the store this morning put it in and cranked the engine and got spark on my pulled plug. Good call on the relays being in different spots on their mountings. They had been switched around too.
I will update on progress once I have finished cleaning the fuel tank and installed my new fuel pump.
Thank you so much for your help
Parker 7 (02-12-2024)
After fuel pump installation rotate the keys several times the run position to charge the fuel lines before starting in the start position attempt
Charging is different than cylinder priming
On fuel pump change it is recommended to change the fuel pump relay and inspect the pump motor connector sockets for burnt sockets
On first rotation of the key before the start position the pump will run for 3 seconds only per key cycle
Leave foot off pedal when starting , there is no goosing to get more fuel
Did you see 300 RPM on the tach indicating good CKPS ?
The following 2 users liked this post by Parker 7:
944play (02-19-2024),
Desert_Man (02-20-2024)
The following 2 users liked this post by Vee:
Desert_Man (02-20-2024),
Parker 7 (02-19-2024)
STR_03
20
09-08-2020 10:27 AM
