crank position sensor X300
Old 05-27-2009 | 07:43 AM
cooke's Avatar
Default crank position sensor X300
Where is the crank position sensor on a 96-97 XJ6 (X300)
Old 06-01-2009 | 01:33 AM
cooke's Avatar
Originally Posted by rvf
At the front of the engine by the pully one 6mm bolt holding it in place.
rvf
THANK YOU
cooke
Old 01-12-2017 | 09:49 AM
Jdogsofla's Avatar
Which pulley? Any one have a pic or a diagram? Thank you!
Old 01-12-2017 | 10:08 AM
Qvhk's Avatar
Default Location of X300 Crankshaft Sensor
Check out pictures in post #330 of the following thread:
https://www.jaguarforums.com/forum/x...-66536/page17/
The following 2 users liked this post by Qvhk:
Don B (01-12-2017), Jdogsofla (01-12-2017)
Old 01-12-2017 | 10:14 AM
b1mcp's Avatar
Save
The following 6 users liked this post by b1mcp:
Don B (01-12-2017), fatelvis (03-14-2019), Jag44 (03-25-2019), Jdogsofla (01-12-2017), MountainMan (01-12-2017), Qvhk (01-12-2017) and 1 others liked this post. (Show less...)
Old 01-12-2017 | 03:11 PM
Jdogsofla's Avatar
That's perfect! Thanks you so much! I'm hoping that's my fix.
Old 01-19-2017 | 02:54 AM
Tcasmarcus's Avatar
I just changed the crank position sensor and i have a question.. the cable end of the sensor with the electric connector is attached to a plate with 2 bolts. When I removed this plate some oil dripped out... What is this "hole" behind the plate? 😶
Old 01-19-2017 | 03:23 AM
The end of the auxillary jackshaft.
I use a good smear of Hi-Temp RTV on that plate, and refitted it.
There is NO seal in there, but a gasket for that plate NBB2119AA I think???
#6 is the plate in question.
Don B (01-19-2017)
Old 01-19-2017 | 03:27 AM
Tcasmarcus's Avatar
Ah yes exactly! Thanks for the clarification. 😀
Grant Francis (01-19-2017)
Old 06-30-2018 | 09:15 PM
sbierwagen's Avatar
Just changed mine, and the sensor was retained with a bolt that had a 8mm hex head. Might have been a 6mm shaft, but the fastener head was of more immediate importance to me at the time.
Detaching the connector was lightly counterintuitive-- the sensor side is stationary, clipped to a retaining bracket, and the harness side is loose. Yanking on the sensor side of the connector doesn't help you none.
Lady Penelope (06-30-2018)
mrplow58
01-21-2024 06:53 AM
RoyLittle0
05-25-2023 03:38 AM
Forcedair1
02-19-2020 02:51 PM
joesoap
09-10-2015 02:09 AM
Doovoe
XJ40 ( XJ81 )
09-06-2015 11:54 AM
Quick Reply: crank position sensor X300
