cupholder in the center armrest
Old 12-26-2021, 12:57 AM
Parker 7's Avatar
I did the same with JB Weld but put in sewing threads on the outside curvature of the hinges to give the adhesive some tensile strength
I found by soaking a bamboo squiwer with vegetable oil and putting in the void ( pivit hole ) that you want it will release just as the JB Weld is starting to set
The same addition of threads was used on other parts on the cupholder like under the long springs
Cafcpete (12-26-2021)
Old 12-27-2021, 12:13 PM
jmstunts's Avatar
I purcgased a brand new one from Welsh Motors in California, around $120.
Jack M
Old 12-29-2021, 05:11 PM
cdma's Avatar
Yea but it will happen again. I purchased one from a company out of Florida for $95 total. I also received a center armrest the other day that actually had two metal hinges on them.
Parker 7 (12-29-2021)
Old 12-30-2021, 10:03 AM
Received 8,092 Likes on 4,881 Posts
The X308 and X100 have the metal hinges on the cupholder from about 2000MY (2001?) onward.
The newer cupholder console trim cover is DIFFERENT and has 'reliefs' for the hinges so they don't really fit the earlier cars.
The metal hinges will 'bulge' the trim lid but might work anyway?
cdma (12-30-2021)
Old 12-30-2021, 11:34 AM
Parker 7's Avatar
CDMA ,
If you have to replace a rear sensor I have some tips
Make sure you have the correct part # referencing the Classic Jaguar Parts website I always reference against your VIN #
The original part has the part # ink stamped on them fortunately
A right will not work on a left and vice versa for some reason
The sensor is a stainlees steel button that goes down into a hole that is cast iron ( the hub )
this presents dissimilar corrosion and penetrating oil days before hand can help
The part that breaks is the external plastic cap where the wires come out and you pry on this and pops off
In your dry environment you have it better then in wet environments for under car corrosion
The sensor connectors go into the cabin and the connectors are under the rear seat bottom pan
Someone found a loose sensor connector or wiring under the seat pan
While you have the bottom pan out you can look on the cars right at the small black triangle cover for the battery cable fuse and tie in point ( loose terminal nuts ? )
I have a pic from someone on a different computer and I think it was Watt700
To not remove the rear seat pan you can splice the wires in on the outside of the car
I have some special waterproof sealing splices I can mail you or you can remove the rear seat pan
Johnken
10-01-2019 08:43 AM
cobratom
06-06-2018 08:24 PM
petthesweaty
05-22-2014 08:25 PM
Andy94SC
03-08-2011 05:55 PM
mtotrainer
01-20-2009 05:48 PM
Quick Reply: cupholder in the center armrest
