Dash/Instrument lights
Further to a recent post regarding a lack of any dash/instrument lights, I have made a little progress but am still in the dark! Just to be clear, the lights in question are those that illuminate the speedo, rev counter, fuel and temp gagues etc.
I discovered that the 10 amp fuse in the rear passenger heelboard had blown. I replaced it, switched on the lights, turned the dimmer switch up slowly and the fuse popped again.
Having poked around under the steering column, suspecting a possible short due to the movement of same,what I know at the moment is this;
The RED/YELLOW supply in to the dimmer carries 11.67 volts. Possibly a bit low as the car isn't in constant use at the moment. The RED/GREY line out carries 9.99 volts. This is with the dimmer switch turned right down to the off position, after the "click". If I turn the dimmer up full they both carry 10.50 volts. The problem arises when I switch the ignition on. With the ignition off, I can turn on my exterior lamps but the dash stays dark. When I turn the ignition on and then the exterior lights, the fuse will blow as soon as I turn the dimmer up about one third of the way. PS. The colour coding given here may be a bit suspect as it was dark under the steering column and the inspection lamp made everything a bit too bright. Anyway, would a possible short at the ignition switch be to blame? Anyone know the colour code/wiring from the ignition switch that feeds the dimmer/lights and is there another circuit in tandem with this one. Confused and bewildered and any help or input greatly appreciated.
Good luck!
rsa760041
23
09-25-2015 01:33 PM
