Dash removal instructions for expansion valve replacement
After replacing my receiver drier and having my condenser flushed out, my AC blows at a maximum 78/80 degrees on high fan and lowest setting.
Pressures measured with a manifold gauge set points to a partially stuck closed/open expansion valve which I think needs replacement.
I was trying to avoid this job because of how much labor is in involved with taking apart the whole dash but now it seems inevitable.
Now for those people that have done the evaporator/expansion valve replacement. Are there any shortcuts to make the job easier/quicker
(Would I be able to reach everything from behind the glovebox)?
If not, is there a write up anywhere I could study to help familiarize myself with everything?
You probably know, having written it this way...but make sure you are aware before pulling the dash apart that the valve is not a service item - comes with evap core attached and is Hella-spensive! Although that's not saying you can't find a suitable valve and effect a swap....
But no one knows of a guide to removing the dash board correctly in order to get to the evaporator/valve assembly?
Rock Auto has the part (GPD Part # 3411483) and I bought one. ($12.58+shipping)
It is the correct part as it is identical to a good used part I saved from a leaking EVAP core. It is JUST THE EXPANSION VALVE!!!!!!!!!!!
I now have a good used valve and a NEW one so I am set for a while.
YES the entire dash assembly must be removed and THEN the climate control box can be removed and disassembled for repair.
If you have never done this repair I would suggest a digital camera or detailed drawings for harness connectors and correct routing.
bob gauff
bob gauff
Ophitoxaemia
09-14-2015 02:40 PM
Bcrary3
08-31-2015 11:29 AM
