Dead ECU/ECM
How do you know the ECU is damaged?
If you take the EPROMs out and fit them to another ECU from an XJRyou will have to orientate the lambda ensors and adapt the closed throttle voltage. This will require workshop diagnostic equipmewnt like WDS, IDS our a more generic tool like Autologic. The EPROMs contain multiple different calibrations. The correct one is selected during end-of-line programming in the factory. This step will be missed if you change the EPROMs in an ECU. The default calibration may not be the same as the one that was selected during the end of line programming, but the car will still probably run OK, as all the calibrations will be for the XJR6 model.
AS PER TSB 05.1-26am5 (T493) the 1995MY XJR PROMS were NOT replaced and only the throttle spring was to be replaced.
Note: On 1995 MY XJR vehicles not previously reworked under
R493, the only repair to be performed under T493 is to replace the
throttle spring.
ALL other ECMs were updated with new PROMS
Vehicle---------VIN RANGE-------- KIT #-----ECM part #--(PROM ID)
95 MY XJ------- 720120 - 754303 LNC 1411AB LNA 1410AL (9361)
96 MY XJ - SWB 754304 - 787953 LNC 1411CA LNA 1410VK (9357)
96 MY XJ - LWB 754304 - 787953 LNC 1411DA LNA 1410DF (9358)
96 MY XJR------ 754304 - 787953 LNC 1411EA LNA 1410SF(9359)
97 MY XJ - SWB 787954 - 812255 LNC 1411GA LNB 1410AE (9353)
97 MY XJ - LWB 787954 - 812255 LNC 1411HA LNB 1410FE (9354)
97 MY XJR------ 787954 - 812255 LNC 1411JA LNB 1410DD (9355)
Years ago a customer bought a 1995-1997 XJR at an auction and brought it to the dealer for poor running and I finally diagnosed it as having the wrong ECM installed. They bought a used one from a salvage yard and that cured the poor running.
You might just need to install the supercharged PROM set into a known good AJ16 ECM.
I don't know if this recall was JUST FOR THE U.S. or for more markets.
bob gauff
throttle spring.
bob gauff
Also need to do the basics, powers & grounds.
Good luck!
New ECM arrived, now have comm with my OBDII (Torque), which I didn't before. However, I think also, both the body processor and TCM got hit by the reverse polarity.
The break does not release the gear shifter, interior lights don't seem to work properly. Still no start, and transmission fault light stay on!
Any more thoughts?
Any more thoughts?
Any more thoughts?
Any more thoughts?
Don't forget the powers & grounds and check all fuses.
Good luck!
