Dealer level OBD2 Scanner
someguywithajag (06-18-2021)
I think I also missed the Genrad 500, 510, handheld reader. There's was one recently on eBay for crazy money. He wanted like $750 for it. At that point, I would recommend the VCM setup over that!
The mongoose should do what you need, but do not settle for the clones. They tend not to work for very long. I believe the VCM setup is probably what you should invest in. I'll wait for others to chime in with their experience.
motorcarman (06-13-2021)
either way that mini vcm won’t work.
you need a gna600, a rotunda vcm or a clone of it. period
I have 2 Rotunda VCMs. (one is Mazda and the other an old Ford unit)
I also have 3 WDS Genrad 3500 PTUs with one docking station.
The WDS will work on Jaguars to 2006 but running a Pentium I 233mhz with Windows 98 will test your patience.
I run the Rotunda VCMs on DELL C640 XP PRO laptops with IDS 118.5.
Rumor has it that WINDOWS 7 32 bit will also work.
The VCMs were easier to find several years ago when all the Ford, Jaguar, Mazda dealers were moving on to better/newer interfaces.
Lots of used VCMs dumped on the used market (eBay?) a decade ago.
I still use my WDS when I am 'not-in-a-hurry'.
You would need to make sure you purchased the Jaguar Expansion pack for AutoEnginuity. I'm not sure anyone has confirmed that it will work to reset TPS, but it should pull all Jaguar specific codes.
