decarbon non-running AJ-16 engine
Resolved
Thanks everyone. I got my car to start today after replacing the fouled NGK iridium plugs and doing the transmission fluid trick. One teaspoon per cylinder.
I also talked to a professional mechanic. He thought I had flooded the cylinders with raw gasoline which wiped out the oil film and hence no compression.
I'll never run the engine for just two minutes again. A wonderful lesson learned. I've been driving that car (1995) since new. I should have known better.
Bill Livingston
Hot Springs, AR.
Bill Livingston
Hot Springs, AR.
I have done it 3. The AJ16's just don't like that. If you are going to move it in the garage to get to another or get out of the way on the driveway, car be prepared to take a 15 minute drive around the block.
OkieTim
09-08-2015 04:48 PM
