delete alarm from ECU
hi all,
for another transplant adventure, I want to use an aj16 4.0 engine. Now I have done a transplant with an AJ6 beforet, but in this case, there is no room for the distributor so I thought I could better go for the aj16 as this one has coil on plug ignition.
however, the alarm for the aj16 is much more advanced. Is there a way to entirely delete the alarm from the aj16 ECU?
thanks already.
Wilfreds
thanks already.
Wilfreds
motorcarman (07-07-2021)
I am located in europe, the Netherlands so the donor car doesnt have American specs and does come with an alarm/immobilizer system. I have done an engine swap with an aj6 before, which didn't have any of this. But also with a 1998 VW diesel, which did come with immobilizer, and an transponder key etc but it was relatively easy to erase this from the ecu.
Now I wonder if it is possible to do this for the aj16 or to shortcut something maybe?
anything to have the AJ16 running without any security/alarm/immobilizer.
seems to be possible to remove it though!
https://www.ebay.co.uk/itm/162399208688
this is what I was looking for.
Tornado Systems advertises that they can do alarm delete; https://www.tornadosystems.com/produ...-supercharged/
you need to send your ecu to them though.
