Diff oil level check.
Old 10-21-2015, 08:19 AM
Mr happy's Avatar
Default Diff oil level check.
Hi all, a couple of weeks ago I came across a thread, I'm not even sure if it was on this site, it was a guy with a x308 who had drilled a two inch hole in the forward wall of the spare tyre well which aligned with the diff fill\level plug which made filling and checking a breeze, well yesterday I done the same to my x300, and yes checking the level is now easy, you can bung the hole up with a rubber blind grommet when done,you still have to crawl underneath to change the oil especially if like me you don't have easy access to a ramp, you guys might already know of this little dodge if so excuse me, if not then it only takes half an hour or so.
The following 3 users liked this post by Mr happy:
Grant Francis (10-22-2015), smartobject (10-21-2015), Tipptone (10-21-2015)
Old 10-22-2015, 04:17 AM
Received 10,475 Likes on 6,918 Posts
A bit radical for me.
I dont find the checking of the diff oil all that bad, and whilst under there I get to have a good gander at all sorts of things that might be needing attention at some time in the future, before they break.
Old 10-22-2015, 05:46 PM
smartobject's Avatar
I really like the idea of being able to use gravity to help putting it back in. I only have a hand-operated pump and if the mileage for the oil change clicks over in the winter... man - I dread that job.
DandyAndy
11-17-2015 04:07 AM
Clayton Webb
10-26-2015 10:56 PM
280zx-turbo
10-21-2015 05:22 AM
nlt624
10-20-2015 11:48 AM
Quick Reply: Diff oil level check.
