DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
#201
Dear All,
The latest batch of brackets are nearly all gone. There are only 2 left. If anyone wants one, then please get in touch. andystodart@metronet.co.uk
#205
Nighteyez
may I humbly recommend combining Andy's bracket with a pod filter to maximize the benefit?
I convinced a 68 mm K&N pod to fit, (I bought the filter on a whim before I had a chance to properly measure the diameter of the plastic pipe behind the airbox), but the appropriate diameter is 75-76 mm. It opens up the top end and with the advanced spark timing, the AJ16 gets a new lease of life...and this is only on the 'baby' 3.2
XJ-Executive (09-10-2016)
#206
#208
Pod filter looks like the link below
it is sort of cylindrical often with an inner surface too, so has a bigger surface area.
there are replacement panel (flat) filters but in my experience with 2 previous non-Jag cars not worth it - same surface area, same restrictive air box.
The pods give a bit more intake noise, but not excessive on my 3.2 and I like the sound. Worth turning the stereo off to hear it..
K&N Universal Clamp-on Air Filters for a Variety of Universal Air Filter Applications
#209
#210
#211
#212
#213
#214
#215
#217
I emailed you regarding the bracket. Suppose you have none left from last order? If not, I would like to put in my humble request for one when another order come round. Thanks!
#219
#220
The following 2 users liked this post by EZDriver:
Benj628 (03-08-2018),
BigBossRadio (09-27-2015)
