DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
#401
#402
I have one of these brackets, unused, that I'm willing to sell. I bought it for a '96 VDP and never installed it.
To be clear, I'm not trying to undercut Andy here, I bought it from him and he couldn't have been more helpful, I just shelved the idea and never got back to doing it.
I'll give it up for the same price I bought it for, again, not to compete with Andy. Message me if you'd like to buy it. Thanks so much.
#403
XJ-Executive (09-10-2016)
#404
AL NZ is right. I can fit one of these brackets in under 15mins on an XJR and that job that includes removing and refitting the SC drive belt tensioner. Fitting my bracket to a US spec cXJR is a little bit more awkward because the secondary air pump obscures the view of the bracket. However, this is not the case with the naturally aspirated engines as the air pump is mounted in the position occupied by the supercharger on an XJR. It should therefore be possible to change the bracket in under 15 mins, assuming nothing is seized.
littlelic69 (02-07-2016)
#406
Double-check your sent-mail. I believe Andy's wife Helen is handling sales now, and at one point in this thread her email address was posted wrongly, missing the "n" in Helen as I recall.
The following 2 users liked this post by aholbro1:
XJ-Executive (09-10-2016),
XJRengineer (03-14-2016)
#407
Thanks for that suggestion, just checked and the info is there ! Dont have a clue why it didnt go to my inbox.
#408
The following 2 users liked this post by haddock:
#409
Hello chaps just a quick update on my "Andy bracket" which has now been on the car for a couple of months. Firstly although the on board mpg calculator doesn't show any great change in fuel consumption, my own rather primative calculations do show a slight improvement of around a two mpg improvement, which means I'm now somewhere around the 26-28 mpg mark, that's general driving on UK (awfull) roads not steady distance driving,which would see this figure improve. The other point of possible interest is my MOT emissions results both prior and after fitment of revised bracket. My last MOT emissions test was two days ago and compared to last year's readings both CO and HC readings are better this year. I didn't use the same testing station each time, although the types of tester were the same, the car has the same exhaust and hasn't been serviced since last year too. This all could be completely meaningless I suppose as there could be so many other variables to take into account which I don't know about. Anyway a worthwhile investment in my opinion.
The following 2 users liked this post by Mr happy:
#410
Hey all, I fitted one of Andys Brackets about a month after purchasing my x300 a year or so ago, I fitted it along with a Short Ram Intake and although I noticed a marked improvement, at the time. I regrettably hadn't done enough driving pre-bracket to make a comprehensive comparison.
This may be a "yeah derrr" comment but I'm always amazed at an oil and filter change, Having just done one I've noticed again an immediate pick up in acceleration, smooth gear change and general feel. This may be a placebo effect but I'm convinced that general servicing is one of the best ways to maintain and improve the performance of our Jags. FYI I do the oil and filter change every 8000km and use a Penrite 20/60 mineral oil.
#411
From what I have seen and read the Mina Gallery kit is not only overpriced, but also pretty cheesy. I took a slightly different route for my XJR6's cold air system from others and chose to retain the K&N panel filter installed by previous owner and added cold air intake ducting to the OEM air box. Incurred approximately $50 US in costs for the PVC pipe and flex piping. Removed the original air inlet horn and replaced with flex routed into the fender well opening. Cut hole in lid of air box and installed 4" thin wall plastic pipe routed down behind the driver side grill. A few photos so you can see what I'm describing.
The following 2 users liked this post by John Dobbins:
al_roethlisberger (03-28-2016),
#412
Finally fitted the bracket to my 95 VDP. I have to say, it was incredibly simple to do. It took me longer to find my 8mm socket than it did to install the whole thing!
I have to say, I've been driving the car harder, and have STILL seen a 3 MPG increase! That's damn near a 15% improvement! As for acceleration, I can't really say. I've also installed a carbon fiber air box with a cone filter inside, and the car feels different overall. A little smoother, but perhaps a bit slower in the low range. I've definitely noticed a big pickup in the higher RPMS however, it almost feels like a turbo. I'm going to try disconnecting my battery to reset the system and see what happens.
I'd definitely recommend this bracket to anyone. It'll pay for itself in no time.
The following 2 users liked this post by Malihide:
XJRengineer (04-16-2016)
#413
#414
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I've tinkered with a similar idea for a while, but it concerned me how the two conflicting input airflows might interact inside the airbox.
If one looks at the airbox, it has embossed directions for the air filter pleats to be parallel to the airflow. And based on some related experience dyno testing stock airboxes, modified airboxes, modified inlet tubes, and no airbox on motorcycles... one might be surprised to find that seemingly obvious improvements such as removing perceived restrictions up to and including the airbox itself can often result in lowered performance. Big shocker, that the engineers sometimes actually knew better
![Icon Rolleyes](https://www.jaguarforums.com/forum/images/smilies/icon_rolleyes.gif)
Can't say that is the case with the XJR airbox, but it is one reason I haven't taken a drill to it yet
Ideally it would be great if someone had access to a dyno and could test several airbox and filter options to see what really delivered better performance. That's the only real way to know.
I can't find the thread at the moment, but there was a recommendation by someone (XJREngineer?) a while back that did some research that just cutting off the tapered "trumpet" on the inlet and extending it with some equal diameter tubing out in front of the radiator did seem to help some.
#415
The previous owner had installed the K&N and was liberal to say the least with the oil, three washes to get clean. I then very lightly oiled and reinstalled at time of putting the whole system back together after cleaning the whole intake from air box to head intake ports. Amazing how much oil can accumulate in the intercooler. Catch can on order to prevent having to do that monster job in future.
I am looking at attempting to fit a dry type pod filter inside the original air box. Will keep all updated on how that goes.
#416
So a little update here.
I reset the ECU and fixed a possible leak in the new CAI (oops?). Immediately I could tell that something was different. Holy hell, it was seriously like having the car in sport mode! Except the milage increased AGAIN. I'm getting 25.6 miles to the gallon after a 200 mile cruise using a rather lead foot. This is compared to the 21 I used to get babying it. It's unbelievable.
I switched to 94 octane just in case, which has the added benefit of being ethanol-free! Being only a few cents more expensive per liter, it's hard to say no to. I really have to say that I'm blown away by the improvement from this little bracket. If you're driving an X300, this is an absolute MUST HAVE. It'll pay for itself pretty quickly. Thank you so much, Andy!
#417
I understand that the XJR ECU runs reasonably rich compared to a NA car. Andy, can you comment if the bracket makes any difference to the Air/fuel ratio?
I have seen a dyno test showing the bracket runs the car slightly leaner (which I would like to do), but I didn't know if it was valid data or not.
#418
#419
Dear All,
Fitting my bracket has no effect on the air:fuel ratio that the engine runs. The engine does run richer than opotimum for best power at engine speeds above about 4000rpm and wide open throttle. Believe it or not, this extra fuel actual cools the exhaust system, which can be necessary if such conditions are sustained for long periods of time, as is possible on an engine dyno. It is not really neceesary if full throttle is only used during brief accelerations. This is why fitting a 10% larger crank pulley can be fitted without making any modifications to the fuelling control. This modification simply makes the engine run a bit less rich.
Thanks to everyone for the positive feedback on the bracket. I have just had the 500th one made, which is something of a milestone, and reflects the continued support from Jaguar owners both here and on other forums.
The following 4 users liked this post by XJRengineer:
#420
Andy: I like the idea of running a bit less rich with the larger crank-pulley. a) May I assume correctly that this improves gas mileage a bit? b) Does this have a +/- effect on responsiveness / performance? I don't want to compromise power. b) If i wanted to install one, do I just ask my jaguar mechanic to look for a pulley that's 10% larger? Or do you have a recommended source / part number? Clearly green-horn questions: sorry.
