DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
#561
Hi XJRengineer, do you know if the internal (not the external harness) wiring harness on the XRJ6 GM4L80E transmission is the same in all of these GM4L80E transmissions or is it also different in the Jaguar. I have a 1995 X300 XJR6. I also purchased one of your brackets back in 2012 and she returns 30+mpg at freeway speeds (110kph) from Gold Coast QLD to Sydney, the bracket is a brilliant modification, thank you.
#562
Hi AL NZ,
I'm relatively new to posting on this forum and I have found it to be a fantastic vault of knowledge. That's interesting about the 1950's Bentleys. You are right on the money re reference to the Jaguar. My current beauty is my seventh and my XJR certainly goes like a scalded cat.
#564
I think ( not 100% sure) that the external wiring harness plug is different, so there will be some slight internal differences. I agree, the the wiring to the solenoids etc is probably the same.
#566
XJRengineer (12-09-2019)
#567
#568
Hi XJRengineer,
thanks for the fast shipping of the bracket to Germany.
I haven't installed the bracket yet.
I have a few question regarding the AJ6 version.
Is there any way to detect a knocking engine in the XJ40?
I think there won't be any check engine light or VCM Message right?
And how long does it take for the engine to reach stable temperatures?
Should i use 98 or 100+ RON fuel if i'm driving 10 or 20 minutes at a constant speed of 200 km/h (120mph)?
#569
Received 12,946 Likes
Hello Browny2,
Welcome to the Jaguar Forums! It's great to have you with us.
You will really enjoy the improved performance and fuel economy after you install Andy's revised CPS bracket. I really liked the results on our '93 XJ40.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (06-27-2020),
MountainMan (06-27-2020)
#570
#571
Hello Bogdan Blazeski,
Welcome to the Jaguar Forums. It's great to have you with us.
Cheers,
Don
Cheers,
Don
93SB (06-04-2020),
#572
Improved performance and better fuel economy is what everybody is looking for but "gizmos" come and go. Now, I ain't saying that this "bracket" is a gizmo but is there any chance of some facts and figures from the folk that have one fitted.
For example, what MPG did you get before and what MPG do you get now?
Also, when you push it, what are the comparative 0 - 60 MPH and 60 - 100 MPH times?
Plus, how many miles per week/month do you need to be doing before the frame becomes viable?
I installed Andy's bracket on our '93 XJ40 with 4.0L AJ6 engine and the difference in performance was instantly apparent, with more immediate engine response from around 2,000 rpm upward. In the 0-60 tests I ran, I could not measure an improvement, but I did all my tests starting from idle. I think if I had revved the engine with the brake depressed before starting each run like any self-respecting street racer, I would have found a measurable difference in 0-60 times with Andy's bracket. There is no question that your "butt dyno" will feel the difference.
One of my friends installed Andy's bracket in his '96 XJ6L with AJ16 and agrees that the difference in performance is not insignificant.
One thing I was able to demonstrate somewhat scientifically is that Andy's bracket improves fuel economy. Here's how I did it: I mapped out a route 60.0 miles long beginning and ending at a Shell gas station. The route, which I measured by Garmin GPS, had only 6 stop signs or lights to minimize time at idle. The elevation change was just over 400 feet (also measured with the Garmin), which is more than I would have liked, but unavoidable in our area. Before installing Andy's bracket, I drove this route four times on different days as opportunities arose. About half of the route was on the Natchez Trace Parkway, a limited-access road with a maximum speed limit of 50 mph. I used cruise control on this stretch to help minimize my own variations in throttle application. At the beginning of each loop, I filled the fuel tank as full as possible at the Shell station, and reset the trip computer fuel economy measurements. At the end of each trip, I again filled the tank, then calculated the fuel economy by measuring how much fuel was used and compared this to the vehicle trip computer (which consistently gave fuel economy averages that were 1 - 2 mpg too low). I averaged the numbers from the four trips. I then installed Andy's bracket and drove the route another four times on different days. This is how I proved to my own satisfaction that Andy's bracket was responsible for improving our fuel economy by nearly 2 mpg (1.9 mpg if I recall correctly).
Assuming your car is in reasonably good tune, you will love the difference with Andy's bracket. One other easy modification that works well with Andy's bracket is to remove the conical snorkel from your air filter housing and replace it with a large straight rubber hose, which will approximately double the cross-sectional area of your intake and further improve engine response at mid- to higher revs, at the expense of a mild increase in induction noise.
EDIT: Well, I just realized that when I clicked on this thread in my Subscribed Threads it took me to Page 1 instead of the most recent page, so I have responded to 5tevie's post from 2012. But I'll leave my post to hopefully persuade others to give Andy's bracket a try. Trust me, you'll love it!
Cheers,
Don
The following 4 users liked this post by Don B:
#573
#574
Can you enlighten us, Andy?
93SB (06-27-2020),
#575
Dear Andy,
years ago I ordered one of your brackets to be installed on my much beloved X306 XJR.
I loved the enhanced performance.
Due to being pensioned of I sold my swift mover, but no stress, bought a very early ‘87 3.6 Sovereign. In good shape, under 200K km’s.
So I’m in dire need of a new bracket.
How do I go about ordening one, it,s been years?
Best regards from Bertus from the Netherlands.
#579
Add a bit of advance (I am guessing there are timing marks) then go for a drive. If it’s not pinking/knocking on your favourite hill, then add a bit more till it does, then take it back a bit
