DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
Old 06-24-2020, 11:50 AM
Received 12,946 Likes on 6,468 Posts
Originally Posted by haddock
After Some quiet contemplation: my early XJ40 has a distributor cap (correct word?) so I think the bracket won’t be of use?
Our '93 XJ40 had a distributor also, but the ECM controlled ignition timing based on the signal from the CPS, so adjusting the distributor had no effect unless you went too far and changed the firing order. I think the problem with your early XJ40 will be that the crankshaft pulley is narrower than on the later 4.0L cars, so Andy's bracket won't align the sensor properly. We'll have to wait till Andy replies to know for certain.
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (06-27-2020), MountainMan (06-27-2020)
  #582
Old 06-24-2020, 12:01 PM
haddock's Avatar
Originally Posted by Cafcpete
Back in the day before knock sensors you drove by ear lol
Add a bit of advance (I am guessing there are timing marks) then go for a drive. If it’s not pinking/knocking on your favourite hill, then add a bit more till it does, then take it back a bit
That’s what I did with my bikes!
Cafcpete (06-24-2020)
  #583
Old 12-04-2020, 10:03 AM
XJRengineer's Avatar
I offer a slightly different design of revised crank sensor bracket for 4.0L and 3.2L AJ6 engines before VIN ending....667829 to replace part number EBC1253. The standard crank sensor bracket after this VIN and used on all AJ16 engines was EBC5017.
Don B (12-04-2020)
  #584
Old 12-09-2020, 03:44 AM
just bought a 96 jag xj6 vanden plas with aj6 yesterday, taking delivery friday. Id like to get one of your brackets. What do i need to do to make that reality ? Thanks!
  #585
Old 12-09-2020, 05:34 AM
bjarnetv's Avatar
just send him/his wife an email at helenstodart@gmail.com to order one.
The following 2 users liked this post by bjarnetv:
LordUnicornFury (12-09-2020), Mkii250 (12-09-2020)
  #586
Old 12-09-2020, 05:37 AM
thanks!
  #587
Old 12-31-2020, 06:42 AM
I don't believe Helen has received an enquiry yet from LordUnicornFury. We have whichever bracket you would require in stock.
  #588
Old 01-01-2021, 02:40 PM
trueci havent, i was thinking of doing the programming mod u offer instead once the intake and exhaust gets fitted late spring. Thoughts on that idea?
  #589
Old 01-02-2021, 06:15 AM
I can reprogramme the ignition timing of your engine ECU. However, you can achieve a similar effect more cost effectively with one of my revised brackets. I only recommend a reprogrammed ECU for owners whole have increased the airflow of their engine by more than 10%, are doing a DIY auto to manual transmission conversion, or fitting the engine into a non X300 vehicle.
The following 2 users liked this post by XJRengineer:
Don B (01-02-2021), MountainMan (01-14-2021)
  #590
Old 01-02-2021, 11:28 AM
my plans are SS headers, Mina exhaust, and Mina air intake, so bracket then? I think im eliminating catalytic convertors in the process too
  #591
Old 01-03-2021, 06:49 AM
A revised crank sensor bracket will work with your proposed changes. I recommend that your new exhaust system includes bosses for the 2 downstream oxygen sensors, even if you don't fit catalysts. This will ensure that you can benefit from closed loop fueling control. If you don't have downpipe catalysts, the catalyst monitor strategy will trigger a fault and turn on the check engine light.
  #592
Old 01-03-2021, 03:32 PM
AL NZ's Avatar
In terms of a Mina cold air intake, I have no experience of them. But I have tried a pod filter in my XJR, and I have reverted to standard filter box and paper filter, for the following reason: I played around with a thermometer on a long wire, taped to the standard snorkel. Even after idling in summer for 5-10 mins after a long hard run, with under bonnet temps around 60'C, when travelling again at say 50-60mph the temp at the snorkel intake would be ambient again after 1-2 miles. In other words, the standard air intake sucks in ambient air when moving at open road speeds.
Also, using an OBDII bluetooth device and iPhone software, I can max out my XJR airflow meter at about 4000-4500rpm at full throttle (I do have a 10% larger Powerhouse drive pulley). So I do not believe the standard set up is restrictive, and I don't think you can improve on intake temps - just my amateur opinion.
If your car is supercharged, a new Bosch electric intercooler water pump is well worth it.
  #593
Old 01-03-2021, 05:15 PM
awesome man! Which means im emailing you to do a bracket now and not having to wait!!
  #594
Old 01-09-2021, 08:37 AM
Oldtomma's Avatar
Hi Andy
you still producing this bracket would be interested in buying one if you are
  #595
Old 01-09-2021, 08:39 AM
bjarnetv's Avatar
Originally Posted by Oldtomma
Hi Andy
He is - just send a mail to helenstodart@gmail.com to order one.
  #596
Old 01-29-2021, 03:29 PM
Ian Booth's Avatar
Hi Don,
Thanks for taking the trouble to provide such detailed feedback on your experience of fitting my bracket. I was disappointed to read that you weren't able to measure a more significant reduction in 0-60mph time given your comment about the subjective feel. However, it can be quite difficult to produce accurate back to back comparisons in vehicle performance. Many factors can create significant differences in tests that were intended to provide back to back comparisons. For instance, testing a vehicle with a full tank of fuel or a near empty tank would change the kerb weight of the vehicle by 3%. Conducting the tests on different days when the ambient temperature varied by 10degC would change the air temperature and hence engine power output by over 3%. The under-bonnet temperature will vary for a given ambient temperature depending on how the vehicle has been driven prior to each performance test. This can also affect the temperature of the air entering the engine.
I hope that you find the increase in performance after fitting my bracket is noticeable, even if you haven't been able to measure an improvement.
Hi Andy
I know this is an old post - but are your brackets still avvailable?
best
Ian
  #597
Old 01-29-2021, 03:33 PM
bjarnetv's Avatar
I feel like this thread will soon consist mostly of alternating posts of people asking if the bracket is still available, and me answering - yes, just send a mail to helenstodart@gmail.com to order one.
Cafcpete (01-30-2021)
  #598
Old 01-29-2021, 04:09 PM
Ian Booth's Avatar
Thank you
  #599
Old 01-30-2021, 10:26 AM
Not only can I confirm that we are still making these brackets, but we have just past the milestone of the 900th bracket. Thank you very much to everyone over the years who have contributed to the success of what has become know in Jaguar circles as, the "Andy bracket".
As others have been kind enough to write, please just contact my wife Helen at helenstodart@gmail.com for more details.
Don B (01-30-2021), SleekJag12 (01-31-2021)
  #600
Old 01-30-2021, 05:14 PM
Ra P Scallion's Avatar
Just picked up my XJR yesterday. One of your brackets was offered to me with the car for a further $100. Having never heard of the idea, or your product, before, I thought about it for a few seconds and said, "Yes please!" Yet to be fitted, but I'm encouraged to find this confirmation that my mental processes are still functioning fine!
Quick Reply: DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
