DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
Old 03-14-2021, 02:01 PM
XJRengineer's Avatar
I'm sure that you will be very pleased with the results after fitting my revised design of crank sensor bracket
  #602
Old 06-26-2021, 10:40 AM
xj40_197042's Avatar
Hello there !
I just ordered and mounted Andy's bracket on my car. It is true, real fuel ecnomy : my car does not start anymore
I certainly do NOT hold the new bracket accountable for this issue (the car started with the new bracket and died 3 kilometer away.
Just posted here because may be some of you did experiment my problem ?
I created a post here : https://www.jaguarforums.com/forum/x...nymore-248186/ : you're welcome to contribute
  #603
Old 06-28-2021, 12:35 PM
Hi Carmelo,
I am really sorry that you have had problems with your car, since fitting one of my revised crank sensor brackets. As discussed by private email, it is possible that disturbing the crank sensor itself, in order to fit the revised bracket, has precipitated a failure of the sensor. If the sensor is original, then it is now at least 28 years old, as your car is a pre 93MY XJ40. These sensors are known to fail, even without being disturbed to fit a revised bracket. I have also tired to answer your question regarding the possibility of fitting an alternative sensor part number, if you chose to replace the sensor. Alternatively, you could fit the original bracket, and check whether the problem now persists, which would confirm that the problem was the sensor, not the bracket. If you ultimately decide that you do not wish to continue with the revised bracket, then you can return it for a full refund.
I very much hope that you are able to resolve your current difficulties, and are able to enjoy the benefits of my revised bracket design.
Regards,
Andy Stodart
The following 2 users liked this post by XJRengineer:
Don B (06-28-2021), xj40_197042 (06-28-2021)
  #604
Old 06-28-2021, 01:16 PM
Hi Andy
Like I said, I'm sure your bracket is not the cause of my problem.
And indeed, as I explained in the subject I've linked in my previous message, I found with the help of the forum the guilty part : it was the rotor inside distributor !
It has choosen to broke 3km after the installation of your bracket !
I receive the new one tomorrow, and I'll try right away your bracket
The following 2 users liked this post by xj40_197042:
Cafcpete (06-28-2021), Don B (12-28-2021)
  #605
Old 12-28-2021, 08:38 AM
I'm glad that you found the root cause of your problem. I'm keen to maintain 100% customer satisfaction with my revised crank sensor bracket design.
  #606
Old 01-17-2022, 03:01 PM
It's good to see that there are still owners of AJ16 and AJ6 powered Jaguars reading this thread for the first time.
The following 6 users liked this post by XJRengineer:
Cafcpete (01-17-2022), Don B (01-18-2022), MikeyB10 (01-18-2022), Mkii250 (01-18-2022), Skantz (09-03-2022), smgdata (03-28-2022) and 1 others liked this post. (Show less...)
  #607
Old 01-21-2022, 11:44 PM
Spud Maat's Avatar
i know i will be organising to get my hands on one soon.....
  #608
Old 01-23-2022, 06:33 AM
DangerPete's Avatar
For the first time and not even owner of a '96 XJR yet. But this could be the case very soon, as I threw an eye on a sapphire blue beauty here in Switzerland, where I live. So a quick hello to everbody on this wonderful forum from a newby. Just wondering, Andy, do you still produce your bracket or do you have anymore available? As I'm preparing the purchase of this wonderful car and intend to visit friends in England as soon as possible, I'd like to ask about availability.
  #609
Old 01-23-2022, 06:42 AM
DangerPete's Avatar
Just saw an older post with your wife's mail. Sorry for disturbing here, I'll send a mail to her.
The following 2 users liked this post by DangerPete:
Cafcpete (01-24-2022), Don B (01-31-2022)
  #610
Old 01-29-2022, 08:55 AM
Yes DangerPete, I still sell my revised design of crank senor bracket. One design is for late 3.6L and early 3.2L / 4.0L AJ6 engines. The other design is for late 3.2L / 4.0L AJ6 and all AJ16 engines. I think the the early / late changeover points seems to be 93MY, so I ask owners to provide engine number and VIN to confirm which design they require.
  #611
Old 01-31-2022, 05:56 PM
Just to add my 2p to the thread as a new first-time owner of an X300 XJR6 Supercharged. I've already purchased one of Andy's brackets but will be driving the car for a bit without it, before fitting so I can make an informed comparison. Will report back.
Oh, and I did the same with Andy's drop-links. Just waiting for the rear anti-roll bar to turn up, which is taking forever from Ultra Racing Shop.
someguywithajag (02-14-2022)
  #612
Old 02-13-2022, 09:45 AM
Redlock's Avatar
Well done Carmelo and thanks for the videos. You have the patience of a Saint. People who don't believe in coincidence should buy a jaguar.
OxfordJoe (05-25-2024)
  #613
Old 03-06-2022, 04:53 AM
Dear All,
I have changed my email address, so anyone wanting more information about my revised crank sensor brackets should contact me on andystodart4@gmail.com
Parker 7 (03-06-2022), Redlock (03-06-2022)
  #614
Old 03-07-2022, 04:00 AM
Cafcpete's Avatar
Dear All,
Hi Andy, is this email now to be used instead of contacting your wife when ordering?
  #615
Old 03-08-2022, 01:21 PM
People are still welcome to contact Helen, who will reply to enquiries. However, some people have been contacting my old email addresss stated on the first page of the thread. This is no longer reliable.
Cafcpete (03-09-2022)
  #616
Old 03-14-2022, 07:52 AM
MattShill's Avatar
Hi there, can I ask if this also fits the 4.0 AJ6 in the XJS? If so, very interested in fitting one
Thanks, from another ex-Jag engineer!
  #617
Old 03-14-2022, 03:50 PM
Yes, I offer revised crank sensor brackets that replace part number EBC1253 that was fitted to 1991 4.0L XJS
MattShill (03-15-2022)
  #618
Old 04-09-2022, 08:13 AM
I've just had another batch of revised crank sensor brackets made for late AJ6 and all AJ16 engines.
VegasBiker (04-29-2022)
  #619
Old 05-14-2022, 03:13 AM
The latest batch of brackets has been very popular, so I have the next batch in production.
Don B (05-14-2022)
  #620
Old 06-18-2022, 01:40 PM
The latest batch of brackets have now arrived.
The following 5 users liked this post by XJRengineer:
Cafcpete (06-20-2022), Don B (06-19-2022), jagy4321 (06-18-2022), klauschou (08-15-2022), SKRTSKRTXJR6 (06-18-2022)
Quick Reply: DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
