DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
Old 08-18-2022, 05:23 PM
klauschou's Avatar
Originally Posted by XJRengineer
The latest batch of brackets have now arrived.
Hi Andy,
Please check the email, waiting for response to buy your bracket. Thank you…^ ^
  #622
Old 09-17-2022, 12:52 PM
XJRengineer's Avatar
The US Dollar is at a 35 year high against Sterling, so now is the ideal time for any US Jaguar owners considering one of my revised design of crank sensor brackets, as they are made in the UK.
The following 5 users liked this post by XJRengineer:
bjarnetv (09-18-2022), Cafcpete (09-17-2022), Don B (09-17-2022), klauschou (09-17-2022), labcoatguy (09-17-2022)
  #623
Old 09-17-2022, 11:45 PM
Spud Maat's Avatar
I sent an email to Helen a couple of days ago, yet to hear a reply. maybe my email has gone to junk?
  #624
Old 09-18-2022, 10:43 AM
bjarnetv's Avatar
new email is andystodart4@gmail.com
XJRengineer (09-19-2022)
  #625
Old 09-19-2022, 09:08 AM
Hi Spud Maat,
I've just repleied.
  #626
Old 01-29-2023, 09:14 AM
Dear All,
I have just made another batch of my revised cranks sensor brackets for late AJ6 and all AJ16 engines. I've been making these brackets now for about 15 years. I think that most Jaguar owners who have heard about my brackets, have bought one by now, if they wanted one. This latest batch may therefore be the last. If anyone has been contemplating fitting one of these brackets, then I would encourage you to get in touch.
The following 2 users liked this post by XJRengineer:
Don B (01-30-2023), Keesh (01-29-2023)
  #627
Old 03-13-2023, 04:03 PM
DangerPete's Avatar
Dear Andy,
I finally did install your bracket after the winter break. I am more than thrilled about the result as most of your customers are. The XJR feels quicker, sharper, more aggressive, from idle to higher revs - very nice and a pleasure to drive. Best of all: After 1'000 miles on French motorways and twisty B-roads down to the south, not driving slowly, fuel economy is better than ever (from 13.5 Litres/100km down to 12.7, which is 22.2 mpg instead of 21 mpg).
Thank you very much for this bracket! I enjoy
The following 3 users liked this post by DangerPete:
Mkii250 (10-02-2023), SKRTSKRTXJR6 (03-13-2023), XJRengineer (03-16-2023)
  #628
Old 03-16-2023, 04:17 PM
Thank yo very much for the positive feedback. I hope that it will inspire other owners to take advantage of the increased performance and fuel economy that you have experienced.
  #629
Old 03-16-2023, 04:29 PM
JezuzNoChill's Avatar
  #630
Old 03-19-2023, 07:46 AM
DangerPete's Avatar
Dear Andy,
The owner of my car repair workshop has restored a XJ40 3.6 Litre and is asking me, if there is also a bracket for this model/motor? Which informations do you need to check the possibilities? Thanks for your help and information.
Greetings, Peter
  #631
Old 03-20-2023, 02:41 PM
Hi Peter, I can provide a revised crank sensor bracket for 3.6L engines after engine number 108834.
Don B (03-20-2023)
  #632
Old 09-03-2023, 09:25 AM
I've just taken delivery of the latest batch of brackets. I had to use a different machinist, as my usual guy was sick. I have to say that the machining on this batch is even better than usual.
The following 4 users liked this post by XJRengineer:
Cafcpete (09-04-2023), Don B (09-04-2023), labcoatguy (09-03-2023), SKRTSKRTXJR6 (09-05-2023)
  #633
Old 10-02-2023, 01:20 AM
@XJRengineer
Have you considered selling the 7 degree timing bracket? Where I live the 100 octane fuel is only 4 cents more expensive than the 95.
Cafcpete (10-02-2023)
  #634
Old 10-02-2023, 03:13 PM
I'm sorry but I don't offer a bracket that is advanced by 7deg, only one that is advanced by 5deg. 100RON fuel is not common in many markets. It is not necessary to use fuel of higher octane than 95RON (approx 90 pump octane / anti-knock index) with my 5deg advanced bracket. I can reprogramme the engine ECU for anyone wanting a more advanced ignition map.
Don B (10-02-2023)
  #635
Old 12-10-2023, 04:53 AM
My revised crank sensor brackets continue to offer the most cost-effective way to improve both performance and fuel economy of any Jaguar fitted with an AJ16 or late AJ6 engine. If anyone has any questions about this modification, then please get in touch (andystodart4@gmail.com)
Cafcpete (12-16-2023), MountainMan (12-18-2023)
  #636
Old 05-11-2024, 06:59 AM
Dear All,
I have 9 brackets left from the current batch that I had manufactured in Auguat 2023. Demand for these brackets has declined over the last few years, as most people who wanted one have now got one, and the number of AJ6 and AJ16 engined Jaguars still on the roads continues to decline. This batch may therefore be the last batch that I make. If not, I will be making any future brackets in smaller quantities, which will inevitably increase the price. If you have been thinking of getting one, then I suggest you don't put it off any longer !
Cafcpete (05-11-2024), Don B (05-11-2024), Keesh (05-12-2024), Parker 7 (05-12-2024)
  #637
Old 05-17-2024, 11:34 AM
cdma's Avatar
Default B30f4 p13b0
With your device and a new sensor I get a pending error. Is that something you have seen
  #638
Old 05-17-2024, 11:53 AM
Parker 7's Avatar
The pending error may have something to do with the the difference from the original and always present mechanical TDC mark on the crankshaft pully ( not missing tooth ) and the 5 o'clock located index position on the engine block
The biased Andy Bracket will now be 5 degrees different when the missing tooth comes around to the CKPS and now not at the same time the 5 o'clock index mark
Your Camshaft position sensor should not need adjustment as it will read original TDC from the cams
The CMPS will be used first in startup and at some point switch over to the CKPS
Your codes could be more of a nuisance from the reader device and not a real functional issue but then you had some misfire issues recently that may only have been codes
  #639
Old 05-17-2024, 03:12 PM
Received 13,186 Likes on 6,548 Posts
Hi Phil,
What is the pending code?
One thing worth checking is the electrical connector for the crank sensor. The pins have been known to back out of the connector, leading to an intermittent connection or no connection. Detach your connector and confirm that all pins are present and of the same length.
Also, is there any chance that any grime or road grit got trapped between the bracket and the timing cover, or between the sensor and bracket? Any misalignment could cause problems.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (05-19-2024), EssOess (05-24-2024)
  #640
Old 05-17-2024, 07:43 PM
cdma's Avatar
The code is B30f4 P13B0. It is a new sensor and a relatively new bracket, but I will check to make sure. I have hardly driven the car since I put them on but it is worth checking
Quick Reply: DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
