DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
#621
#622
The following 5 users liked this post by XJRengineer:
bjarnetv (09-18-2022),
Cafcpete (09-17-2022),
Don B (09-17-2022),
klauschou (09-17-2022),
labcoatguy (09-17-2022)
#623
XJRengineer (09-19-2022)
#625
#626
Dear All,
I have just made another batch of my revised cranks sensor brackets for late AJ6 and all AJ16 engines. I've been making these brackets now for about 15 years. I think that most Jaguar owners who have heard about my brackets, have bought one by now, if they wanted one. This latest batch may therefore be the last. If anyone has been contemplating fitting one of these brackets, then I would encourage you to get in touch.
#627
Dear Andy,
I finally did install your bracket after the winter break. I am more than thrilled about the result as most of your customers are. The XJR feels quicker, sharper, more aggressive, from idle to higher revs - very nice and a pleasure to drive. Best of all: After 1'000 miles on French motorways and twisty B-roads down to the south, not driving slowly, fuel economy is better than ever (from 13.5 Litres/100km down to 12.7, which is 22.2 mpg instead of 21 mpg).
Thank you very much for this bracket! I enjoy
The following 3 users liked this post by DangerPete:
#628
#630
The owner of my car repair workshop has restored a XJ40 3.6 Litre and is asking me, if there is also a bracket for this model/motor? Which informations do you need to check the possibilities? Thanks for your help and information.
Greetings, Peter
#632
The following 4 users liked this post by XJRengineer:
#633
@XJRengineer
Have you considered selling the 7 degree timing bracket? Where I live the 100 octane fuel is only 4 cents more expensive than the 95.
Cafcpete (10-02-2023)
#634
I'm sorry but I don't offer a bracket that is advanced by 7deg, only one that is advanced by 5deg. 100RON fuel is not common in many markets. It is not necessary to use fuel of higher octane than 95RON (approx 90 pump octane / anti-knock index) with my 5deg advanced bracket. I can reprogramme the engine ECU for anyone wanting a more advanced ignition map.
Don B (10-02-2023)
#635
The following 2 users liked this post by XJRengineer:
Cafcpete (12-16-2023),
MountainMan (12-18-2023)
#636
Dear All,
I have 9 brackets left from the current batch that I had manufactured in Auguat 2023. Demand for these brackets has declined over the last few years, as most people who wanted one have now got one, and the number of AJ6 and AJ16 engined Jaguars still on the roads continues to decline. This batch may therefore be the last batch that I make. If not, I will be making any future brackets in smaller quantities, which will inevitably increase the price. If you have been thinking of getting one, then I suggest you don't put it off any longer !
#638
The pending error may have something to do with the the difference from the original and always present mechanical TDC mark on the crankshaft pully ( not missing tooth ) and the 5 o'clock located index position on the engine block
The biased Andy Bracket will now be 5 degrees different when the missing tooth comes around to the CKPS and now not at the same time the 5 o'clock index mark
Your Camshaft position sensor should not need adjustment as it will read original TDC from the cams
The CMPS will be used first in startup and at some point switch over to the CKPS
Your codes could be more of a nuisance from the reader device and not a real functional issue but then you had some misfire issues recently that may only have been codes
#639
Received 13,186 Likes
What is the pending code?
One thing worth checking is the electrical connector for the crank sensor. The pins have been known to back out of the connector, leading to an intermittent connection or no connection. Detach your connector and confirm that all pins are present and of the same length.
Also, is there any chance that any grime or road grit got trapped between the bracket and the timing cover, or between the sensor and bracket? Any misalignment could cause problems.
Cheers,
Don
#640
