Does my check engine light work?
hi, I was wondering if my check engine light works? Because when I take my car to a jaguar repair shop, it shows a faulty tps sensor which was fixed, egr valve, and fuel injectors. I dont have any of this, even when I scan with a generic nothing comes up. Anyone know anything? thanks.
Received 10,880 Likes
First, whenever a repair shop suggests x-y-z repairs *ask* them why they are needed and how they determined what the faults were, what the tests results were, etc. This doesn't have to be, and shouldn't be, adversarial.
As for check engine lights.....
Different faults have to fall within predetermined parameters before triggering the CEL and setting a code. Length failure "events", ignition key cycles, miles driven, engine and/or road speed...all sorts of stuff....can go into setting up the failure parameters. My experience with my '95 XJR is that the system is generally reluctant to set a code and turn on the CEL.
Sometimes a shop can evaluate live data from a scan tool and identify problems that haven't fallen through the window to turn on the CEL.
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Fraser Mitchell
10-01-2015 04:06 AM
SingBlueSilver
08-27-2015 02:20 PM
