Door issue!
Rear passenger side door will not open from the inside. I assume that the cable or something has slipped or detached. Does anyone have a diagram or instructions for removing the door panel without damaging it and do I have to disconnect the battery as the locking system is electronic? Any help appreciated. Thanks!
Can't help with a wiring diagram unfortunately, but is it possible that it is set to "child proof" thereby not allowing it to be opened from the inside? Funny that its only one door and not both if this is the case. Have you tried locking and unlocking all doors from both inside and outside the car? It does sound as though an actuator may have come disconnected, but I dont know how easy, if even possible it is to remove a door card with the door closed! Sorry not to be of any more help.
you shouldn't need to disconnect the battery.
to remove the door panels, there is a screw underneath a little black cover on the chrome door handle, remove that, then carefully pull the wood paneling towards the front of the vehicle, it should slide out, then two or three screws holding the top panel on, and it comes right off.
the bottom panel is removed by removing the screw on the underside of the pull handle, and the rest of the panel is held in place with plastic rivets, just use a big screwdriver or something to pop them loose.
Guest
Posts: n/a
Sacjag,
I am having the same issue with the driver's side door. When i tried to open it today from the inside, it made a popping sound, then won't open with inside handle. I have an XJ8, could you tell me about your experience with taking off the door panel. I think this is a cable problem on mine.
Thanks,
Michael
Thanks,
Michael
Wolfy
05-28-2024 08:06 AM
99xk8guy
06-05-2023 06:28 AM
WinterJag
16
10-09-2015 07:49 PM
