Door lock cable keeps breaking. Any way to reinforce it?
In 2 years, I've broken the driver's door lock cable 3 times.
Before I replace the cable again (easily a 2 hour operation), do you guys have any guesses as to what I'm doing wrong?
It works fine for a while, then it seems I have to pull the handle further and further away, until the door doesn't open or the cable snaps.
I wonder if the switch is flaky or maybe the lock mechanism needs to be greased to work smoother.
Thanks.
Thanks.
Received 1,040 Likes
Cafcpete (05-30-2024)
