Are door lock motors universal?
Hey Lads,
Need to pick up a replacement actuator motor for my drivers door and wondered if all 4 doors use the same motor? I assume they do and they all look similar.
Wanting to maybe grab a motor off something other than the drivers door as they would have been cycled less.
B
B
Jaguar sells the motor and the latch as a complete assembly so naturally each position would have a different part number
If you opened up the assemblies my guess...and that's all it is....would be that there are two different lock motors, with left front and right rear being the same, and vice versa.
The following 3 users liked this post by overtheatlantic:
All I can see is that they mount from one side or the other based on location left or right. Are the screws that hold it on to the assembly a plastic tapping screw of some sort? I don't see a metal insert on the mounting tabs from pics I have seen on the net
Hi Bernie,
This won't answer your questions directly, but since I just looked this up for a thread in the XJ40 forum I'll post it here as well in case it's of interest. Joe77 at the Jag-Lovers forum managed to resuscitate an actuator in his '94 XJ40 by cleaning and lubricating the motor and he posted photos here:
Fixing Door Actuator Motor
Cheers,
Don
Cheers,
Don
MountainMan (02-17-2017)
