Draining Diff & replacing oil. Only OEM mineral oil?
Received 10,901 Likes
I use ordinary [Valvoline] [Shell] [Quaker State] [whatever is on sale that day] 80/90 gear lube. If you have limited slip use LSD additive or buy the gear oil that's labeled "for limited slip".
Not sure about your bit of the world, but down here, most diff oils are LSD compatible, coz a non-LSD diff does NOT get hurt with LSD oil, but a LSD diff with non-LSD oil is not a good idea.
Some of the cheaper brands are still LSD specific, and the synthetics are a maze and I dont use them.
If in doubt use a good quality LSD oil, and drive on, as Doug said, different markets got different specs, such as ALL V12 are LSD.
My 3.2 is non-LSD, and it just got changed with Penrite 80W/90 LSD oil coz that was on special on that day.
If you have an LSD or not is an easy check though. Rasie the rear of your car so both of the wheels are of the gronud then turn one wheel.
If the other wheel goes the same direction the you have an LSD and if not you don´t.
And any diff oil should work these cars hava Dana 44 axles same as in alot of American cars
I have a rebuilt Power-Lok diff/final drive in my 96 XJR6 - the previous owner had it the pinion shaft seal replaced and the shop did not stake the pinion nut in place - it got loose while driving -> not good, at all...
I have been using Motorcraft 75W-140 with the Motorcraft XL-3 limited slip additive in it. Works great. I read that some of the older Salisbury differentials used in XJ Series I/II/III, XJS, and E-Types used leather seals that are supposedly not compatible with synthetic gear oils. The later X300 diffs (same construction) but updated seals will be fine with synthetic gear oil.
