Draining fuel tank
Old 07-26-2020 | 12:51 AM
Parker 2's Avatar
Behind the left rear tire is the fuel filter . the inboard line goes up into the fuel tank
Old 07-26-2020 | 12:54 AM
Rohanc's Avatar
Thank you Parker 3
Can I get to the fuel lines at the tank without removing the diff carrier
Rohan
Old 07-26-2020 | 02:14 AM
Yes you can.
BUT be careful as there is a tin shield thing just nearby that will cut the hell out of you.
The pipes are the "Quick connect" style, and the special tool, readily available, is needed.
PUSH UP on the pipe, with the tool inserted as one unit, then withdraw as one unit. Some fuel splillage will happen, but not much.
I am assuming the system has been de-pressurised?????
Parker 2 (07-26-2020)
Old 07-26-2020 | 11:43 AM
aholbro1's Avatar
Rohanc, try clicking the link at the top of post #19
Michael Hegardt
02-18-2020 08:25 AM
2jags1993
XJ40 ( XJ81 )
09-04-2019 12:36 AM
wjd03
11-30-2016 08:57 AM
Devsta
07-15-2013 03:12 PM
porschegonzo
06-03-2008 12:15 PM
Quick Reply: Draining fuel tank
