Driver side turn signal not working..
Hello... I just had some bumper work done and noticed that the turn signal was not working. I thought it was a bulb so I took it off and replaced, and it still did not work. I also checked fuses, all seem fine. I also swapped lamp bulb sockets from other side and it works on the other side but not on the driver side. I did a circuit test and only 1 out of the 3 pins inside the connector light up with power. Other side all 3 light up and everything works fine. Does anyone think this is a harness issue??
Wolfy
05-28-2024 08:06 AM
