Drivers side front latch assembly needed
Hello,
My X300 cable broke on the driver's side front door lock. I have a new one and tried to attach to the latch side. I ended up taking the latch out completely, and the plastic connectors from the exterior handle links are cracked. I also wasn't able to attach the cable to the latch assembly, it wouldn't stay on the assembly. I need help, it would be easier for me to just install a complete latch assembly with cable and I can attach it to the interior door lock.
Help, Help, Help.
Rande
Help, Help, Help.
Rande
There is a tiny circlip on the aft end of the interior pull cable
it may have fallen down inside the door sheet metal
If you can't come up with one I can pull one for you at the salvage yard I visit
You can call them and have them ship a latch assembly but I wouldn.t expect the clip to be included but just lost along the way
Make sure you tell them the year and inline 6 as they have one but may be subject to selling the whole door
A damaged V8 version may work if they have a damaged door and on inspection can see that they are compatible
Avenue Auto Wrecking (avenueautoparts.com)
02-25-2013 10:27 PM
