ECU repair - 1995 XJR6
Is there a source for replacement ECU connectors? The ones that are attached to the circuit board, not the wiring harness side.
The #18 pin in the black plug is broken on the ECU for my '95 XJR6 and it looks like replacing that whole plug is the best option. Otherwise, the ECU is basically immaculate.
I grabbed an ECU from a junkyard '95 XJ6 and could use the connector on it, but I'd feel bad about destroying a functional ECU, since they are prone to water damage. I'd rather buy a replacement plug if it was available.
So are they available anywhere? I did some searching but had no luck.
The following 2 users liked this post by V126man:
b1mcp (08-13-2021),
thekiltedwonder (08-13-2021)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20210813_102802_892_a11eaccdfd8785c7e9c762c2b5d291e1d969ebd2.jpg)
Searching for that one did lead me to the Econoseal ES3.WTB-36P, which is the right one. I have to show some love to corsa-technic.com. I called them and the girl pulled one off the shelf and took measurements to verify that.
Thanks again for pointing me on the right path.
b1mcp (08-14-2021)
I'm completely unfamiliar with all of that. It sounds plausible, but I found a replacement connector for <$20 shipped, so I'm going to go that route.
